Date/Time: Sun, 12 Jan 2025 23:29:55 +0000
ZZ study API
View Count: 701
[2017-03-20 12:54:19]
User12089 - Posts: 361
what is the API(s) for getting ALL available params/outputs of the ZZ study and the ZZ Cumulative Volume study
I am looking for something similar to the following which is for the Numbers Bars study:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scVolumeAtPriceForBars
[2017-03-20 17:30:13]
The most you can do is access the Study Subgraphs from the Zig Zag study. Refer to:
http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#UsingStudyData
[2017-03-20 18:01:44]
is the original code of these two studies in the directory ACS_Source in files zz.cpp and zzvolume.cpp or the code there is just a sample code
[2017-03-20 22:09:53]
The source code is available and how to locate it is explained here:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn
