Date/Time: Sun, 12 Jan 2025 23:40:28 +0000
Problems with the real-time forex data
View Count: 661
[2017-03-20 11:03:04] |
RQ - Posts: 50 |
I recently fired up SC again for the sole purposes of running market profile on forex data. I'm on package five and the data feed I selected is SC Forex (FXCM) [data]. The chart updates when I connect the data feed but unfortunately it doesn't update any further from this point. It just sits there with nothing happening. I don't need trading data (at least for now) I just need live and historical data for the profile charts. Have I selected the correct feed? I think I should have made the situation more clear in my previous post. I have a green box confirming I'm connected to the above data feed. If I manually disconnect and reconnect to the data feed the chart will update to the current price tick. But unfortunately it doesn't update from this point on; I cannot figure out why. What am I missing? Date Time Of Last Edit: 2017-03-20 11:25:15
[2017-03-20 13:48:43] |
RQ - Posts: 50 |
I've got it working. I moved from the data feed above to "SC Data - all Services" this seems to have done the trick.
[2017-03-20 17:36:13] |
The issue most likely had to do with the Symbol Settings not being up-to-date. Refer to: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#UpdateSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
