Date/Time: Mon, 03 Feb 2025 17:13:17 +0000
Stacked Imbalance with Numbers Bars
View Count: 7709
[2017-03-19 15:55:00]
sellis67 - Posts: 105
is there a way to show stacked imbalance with the numbers bars?
[2017-03-20 17:53:46]
gomifromparis - Posts: 244
I don't think the number bars can show the stacking.
Sorry for self-promotion, but FYI the following commercial study has this : https://www.gomicators.com/gomorderflowpro/
You can check the attached chart
imagesierragom.png / V - Attached On 2017-03-20 17:52:06 UTC - Size: 100.76 KB - 5119 views
[2017-03-20 17:59:01]
don't be sorry for self promotion. I need help and you're providing it. Quick question re: order flow indicators. What really separates an order flow indicator from another one if they all read current data? Are there subtle changes to the programming? Is Ninja capable of being more accurate than other programs because it's a heavier program? I'm looking at Gom, Order Flows, Emoji, NOFT, etc. I don't really know how to differentiate between them or to choose the best one for me. Any insights would be great.
[2017-03-20 18:15:06]
They all use the same numbers, bid/ask data, they will all show more or less the same charts. Each implementation will have different bells and whistles, so you need to check what suits you best.
Ninja will not be more accurate.
For the Gom studies, it is the exact same C# library on all platforms, so they will all generate the exact same charts (on NT7 NT8 and Sierra)
[2017-03-21 06:35:21]
binaryduke - Posts: 377
Another approach:
https://www.emojitrading.com/stacked-imbalances/
[2017-03-21 07:11:43]
Thanks. I'm familiar with emoji and it looks great but there are no videos and no trial period for me to work with. It's hard for me to see how everything works from a print out.
[2017-03-21 07:23:52]
As the developer of emoji I can confidently tell you that there's a 7-day trial period on the 3-month subscription to the Order Flow Suite. This is documented on the home page and FAQs. Feel free to drop us a line to speak in more detail.
Apologies to all for continued vendor self promotion. Will exit this thread now.
[2017-05-19 06:55:15]
@sstfrederik - Posts: 405
Hi sellis67. As an independent SC developer I have created a stacked imbalance study as well. Feel free to try it out. Send me an email. frederik@simplesystemtrading.com
[2019-09-01 10:25:56]
Terry Ko - Posts: 21
Hi sstfrederik, may I contact you, I already sending email to you. Pls check. thanks.
[2019-09-03 15:47:21]
John - SC Support - Posts: 37667
Also refer to the following for another option within Sierra Chart that you can use to see a Stacked Imbalance:
Volume at Price Threshold Alert V2: Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance)
[2019-09-05 08:37:13]
thanks, let me try.
[2019-11-27 15:59:57]
User881696 - Posts: 16
Sierra Charts Numbers bars provides all the order flow information anyone needs. It just a matter of relating the information. I've used CQG IC, Ninja Trader Order Flow Suite, Delta Print, and Gomi. They all have useful order flow data, some more than others, but hands down, for the money and the information you get, Sierra Charts is where it's at....
[2019-11-29 16:50:55]
Thank you. That is good.
