Date/Time: Mon, 13 Jan 2025 00:01:40 +0000
Chart Drawing Adjust To Tick Size
View Count: 690
[2017-03-18 18:07:15] |
b3cker - Posts: 34 |
Unable to use tool (triangle and others). Tool snaps outside of the bar range. This happens when SC is in mode (set all: include weekends, include columns with no data, include columns with no trade) See attached
sc_error_snap.PNG / V - Attached On 2017-03-18 18:06:35 UTC - Size: 37.92 KB - 222 views |
[2017-03-18 18:19:59] |
This is because this option is enabled: Chart Drawing Tools: Having Tool Values Adjust to the Nearest Tick This happens when SC is in mode (set all: include weekends, include columns with no data, include columns with no trade) See attached
This is not the reason.
