Date/Time: Sun, 12 Jan 2025 23:33:28 +0000
multiple sierra instalation
View Count: 551
[2017-03-18 12:01:36] |
User30743 - Posts: 365 |
hi, i use multiple sierra chart instalation (3 - at three laptops) and i trade on all of them - is it possile to see the trading result intergrated into one copy only?
[2017-03-18 19:21:53] |
If you are referring to the historical order fills data, it can be exported and imported. Refer to: Trade Activity Log: Importing and Exporting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
