Date/Time: Sun, 12 Jan 2025 23:58:44 +0000
Possible to freeze usage time while not using Sierrachart
View Count: 804
[2017-03-18 09:18:38]
User17477 - Posts: 65
Hi SC support,
Due to other unforeseen commitments I will not be using Sierrachart for a while. Is it possible to freeze my credit and start again at a later date?
thanks
[2017-03-19 06:45:15]
This would only be the case if you are paying for shorter periods of usage time. In this case you can just disable automatic renewal.
However, contact us here about this:
https://www.sierrachart.com/usercp.php?page=SupportTickets
[2017-03-20 16:37:48]
Im not paying for shorter periods of time. So your answer is no. Ok, understood.
[2017-03-20 16:46:45]
Please contact us here about this:
