Date/Time: Sun, 12 Jan 2025 23:59:05 +0000
Bollinger Squeeze 2
View Count: 1426
[2017-03-17 17:53:05] |
User26753 - Posts: 43 |
Where can I find information about this indicator?
[2017-03-17 18:48:30] |
From our perspective this is just one of these confusing indicators which is a combination of multiple other studies. We can give you the source code for it but it is not likely we would spend any time documenting it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-17 19:22:25
