Date/Time: Sun, 12 Jan 2025 19:05:45 +0000
Switching Chartbooks - Chart Order
View Count: 628
[2017-03-17 09:06:54] |
User730732 - Posts: 12 |
Hi SC, if one has several charts on top of each other, they get rearranged when switching the chartbook. the most recently created gets on top. can this be fixed? Best Regards, Thank you in advance! |
[2017-03-17 10:00:36] |
You need to control the ordering through Windows and Chartbooks. Refer to: Window, CB and CW Menus: Windows and Chartbooks (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
