Date/Time: Sun, 12 Jan 2025 19:06:57 +0000
order lines in fill space
View Count: 562
[2017-03-17 03:56:18] |
aydex - Posts: 110 |
is there a way to remove the order lines extednding all the way to the right edge, as ive attemtpted to clear the right side of chart using Lock Fill Space http://www.sierrachart.com/image.php?Image=1489654248419.png |
[2017-03-17 04:18:58] |
Not exactly. However, refer to this section as to what you can do: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#AlignOrdersPositionToRight Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
