Date/Time: Sun, 12 Jan 2025 19:19:01 +0000
Market Statistics
View Count: 798
[2017-03-17 02:31:44] |
User713688 - Posts: 25 |
Ive been looking for the $TICK and $ADD and have not been able to locate them. Where can I find them? The page below which was "*Last modified Friday, 24th February, 2017" shows that at least the $TICK is avail but there is no reference to the $ADD. http://www.sierrachart.com/index.php?l=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=MarketStats |
[2017-03-17 07:11:21] |
Disregard that page. This is the page you are looking for: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
