Date/Time: Sun, 12 Jan 2025 19:08:48 +0000
How to align spreadsheet calculation with price on chart
View Count: 552
[2017-03-16 22:26:49] |
gmax1mum - Posts: 4 |
I would like to have a value from a spreadsheet study printed as text at price levels. This is just for order flow purposes so that I can see the value Im needing right at traded price, ie. volume traded with each uptick etc. I will attach picture of what I am referring to. Would anyone here know how to go about doing this? Thanks in advance. |
Attachment Deleted. |
[2017-03-16 23:19:38] |
Sawtooth - Posts: 4149 |
Try this: - Put the price level in row 3 of Formula Columns. - Put the value in row 2, forced to text: =TEXT(value) - set the Draw Style to Text - check 'Name Label' - set Horizontal Align to Right or Right Edge. Date Time Of Last Edit: 2017-03-16 23:28:27
[2017-03-17 10:19:06] |
This is the Draw Style that you will want to use: Chart Studies: Value of Subgraph (ACSIL: DRAWSTYLE_VALUE_OF_SUBGRAPH) Really would be best to use ACSIL for this: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-17 10:19:39
