Date/Time: Sun, 12 Jan 2025 19:08:22 +0000
Add 3 & 4 std dev in the VbyP study
View Count: 605
[2017-03-15 16:12:01] |
sierra28 - Posts: 120 |
hello support. Not so important but two std dev is not enough. thanks |
[2017-03-15 20:57:28] |
Refer to: Using the Basic Arithmetic Studies See if you can use the Study Subgraph Standard Deviation study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
