Date/Time: Sun, 12 Jan 2025 19:12:22 +0000
Files to open on startup
View Count: 1062
[2017-03-15 15:42:45]
mdas013 - Posts: 4
Hello.
I have a problem with automatic opening chartbook. I picked one after the opening, but just after the launch open. Only works automatically connect to TWS for streaming data.
Please advice what is wrong.
Thank you
imageoc.jpg / V - Attached On 2017-03-15 15:42:28 UTC - Size: 152.22 KB - 260 views
[2017-03-15 20:58:27]
If the problem is the Chartbook is not automatically opening, then refer to:
General Settings Window: Open Files On Startup (Global Settings >> General Settings >> General >> Startup)
Date Time Of Last Edit: 2017-03-15 21:22:05
[2017-03-15 21:09:58]
mdas013 - Posts: 4
I have it set up as described. I sent a screenshot. Yet to me it does not work.
[2017-03-15 21:13:39]
Is Safe Mode enabled on the Sierra Chart Login window?
You will need to restart Sierra Chart to find out.
Date Time Of Last Edit: 2017-03-15 21:13:53
[2017-03-15 21:17:24]
mdas013 - Posts: 4
Great, that's it. Thanks.
[2017-03-15 21:22:43]
We also realize we gave the wrong link in post #2. It is now updated.
The new link refers to the section that describes the relevancy of Safe Mode.
