Date/Time: Sun, 12 Jan 2025 18:53:49 +0000
Tick Size Of Chart
View Count: 946
[2017-03-14 19:26:37] |
CustomIndicators - Posts: 126 |
Using ACSIL, how can I get the tick size of a chart? If I have a 500 tick chart open, I would like it to return 500.
[2017-03-15 03:14:26] |
Refer to: ACSIL Interface Members - Variables and Arrays: sc.TicksPerBar / sc.NumberOfTradesPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-15 03:16:08
