Date/Time: Sun, 12 Jan 2025 18:40:06 +0000
Move/Rearrange ChartBook Tabs
View Count: 824
[2017-03-14 18:44:02] |
6c7574686572 - Posts: 20 |
If you have multiple chartbooks open, I don't see a way to rearrange them (the tabs). It works with attached charts.
[2017-03-14 20:09:16] |
No, these cannot be rearranged after the Chartbooks have been opened.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-14 20:09:27
