Date/Time: Sun, 12 Jan 2025 19:00:10 +0000
Copy chart drawings do not show up from some source charts
View Count: 861
[2017-03-14 15:07:29] |
User299392 - Posts: 216 |
It works in case of some source charts. With the target chart kept the same; it does not work from other source charts? Please???? |
[2017-03-14 17:10:13] |
Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ChartDrawingsDoNotCopy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
