Date/Time: Mon, 20 Jan 2025 04:07:15 +0000
How to enable Bitfinex exchange data?
View Count: 3231
[2017-03-14 15:00:37] |
Aeon Trader - Posts: 2 |
I have a Bitfinex account and see the option under Data Service in Sierra Chart, but am not able to connect. Please advise. Thank you
[2017-03-14 17:11:21] |
For the data for this exchange, follow the instructions on this page: http://www.sierrachart.com/index.php?page=doc/Bitcoin.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-14 17:11:31
[2017-03-14 18:34:23] |
Yes, I have explored this option but it only lists a minimal number of cryptocurrency pairs.. no where near the number that Bitfinex offers through their web portal. How can I pull in data for other altcoin pairs offered via Bitfinex?
[2017-03-15 03:42:35] |
We will have to add the additional symbols.
[2017-12-09 18:26:43] |
User559414 - Posts: 2 |
Hey Is Bitfinex API still supported? I am unable to connect.
[2017-12-11 04:05:13] |
Only market data is supported now. Refer to: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-12 13:45:40] |
User132576 - Posts: 5 |
Do you have any news on when live trading will be supported?
[2018-01-12 19:02:50] |
This is hard to estimate. And we are also working towards a decentralized exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-12 19:03:58
[2018-05-28 08:21:48] |
User523480 - Posts: 18 |
If I understand it right. At the moment we cannot trade via sierra charts but only use the plateform for charting as far as crypto is concerned?
[2018-05-28 21:34:09] |
Yes this is true in regards to Bitfinex. For trading you can use BitMex instead: http://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-31 06:17:15] |
Bitmex just has futures in Crypto while Bitfenix allows you to trade crypto with less margin and initial balance as the positions can be a lot smaller.
[2018-05-31 06:52:26] |
That does not make sense. BitMex has very high leverage capabilities which would mean less margin and you can trade as little as 1 Satoshi unit.
