Date/Time: Sun, 12 Jan 2025 18:29:27 +0000
autoload startup unfunctionality
View Count: 898
[2017-03-14 05:53:59] |
User622587 - Posts: 16 |
none chartbooks opens when launching SC. platform, while some are autoload startup set up (see capture ples.) What's wrong here ? Date Time Of Last Edit: 2017-03-14 05:56:32
2017-03-12_1539.png / V - Attached On 2017-03-14 05:52:32 UTC - Size: 52.52 KB - 243 views |
[2017-03-14 10:13:34] |
Most probably because you have enabled Safe Mode on Login Window. This is explained here: General Settings Window: Open Files On Startup (Global Settings >> General Settings >> General >> Startup) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
