Date/Time: Sun, 12 Jan 2025 18:33:46 +0000
Moved from FXCM to Forex.com
View Count: 579
[2017-03-14 03:45:37]
WYFB - Posts: 9
FXCM got kicked out of US and Gain Capital bought FXCM's accounts. Then set us up with Forex.com, which is directly with Gain capital. My account $ is with Gain Capital. You(SC) have a gain Capital connection, however, Forex.com is not listed with GC's introducing brokers in your GC set up instructions. I do not want to stop using SC. Is there a way that I can be with Forex.com and still use SC?
[2017-03-14 04:11:16]
Yes. When you use the connection which is described here:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php
You can do Forex trading. You do not need to go through an introducing broker. You can be direct with Gain Capital/Forex.com. Just let them know you are using the Gain Capital Futures connection.
