Date/Time: Sun, 12 Jan 2025 18:55:01 +0000
Horizontal Line Limit
View Count: 655
[2017-03-14 01:12:13] |
User15952 - Posts: 132 |
Is the horizontal line limit set to a max of 40? Can this be changed? http://i.imgur.com/lqTVf4T.png |
[2017-03-14 04:13:38] |
We will increase this to the maximum which is 60.
[2017-03-14 04:19:40] |
Why not just make it 500, 60 is too low
[2017-03-14 04:25:34] |
That is a total impossibility. The maximum number of Subgraphs per study is 60. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-14 05:14:16] |
When will the 60 update happen? Thanks |
[2017-03-14 05:23:01] |
We are putting this out now in the latest prerelease.
