Date/Time: Sun, 12 Jan 2025 18:52:31 +0000
In region 1 I cannot remove the unneccesary information
View Count: 626
[2017-03-13 22:32:08] |
Executor - Posts: 40 |
Displayed in the attached pictures, There is no global chart settings, which could be the issue. Also why is there a chart settings when global chart settings overrides it. The pictures attached will explain the steps taken and unnecessary information not wanted. Also would like the current value removed from daily chart, highlighted on y axis. |
Dont Want.PNG / V - Attached On 2017-03-13 22:31:21 UTC - Size: 27.43 KB - 226 views want this displayed instead.PNG / V - Attached On 2017-03-13 22:31:26 UTC - Size: 20.21 KB - 238 views Changed this as well.PNG / V - Attached On 2017-03-13 22:31:36 UTC - Size: 47.2 KB - 229 views Y-Axis - Remove.PNG / V - Attached On 2017-03-13 22:31:41 UTC - Size: 26.59 KB - 223 views |
[2017-03-14 03:16:49] |
To customize the Chart Header line, refer to: Working With Charts: Region Data Line / Chart Header You can only change the color of the last trade price box on the right side of the chart. Refer to: Graphics Settings Also why is there a chart settings when global chart settings overrides it. This is too vague and does not make sense to us because there are no global Chart Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-14 03:17:24
