Date/Time: Sun, 12 Jan 2025 18:34:29 +0000
Display Name and Value in Region Data Line
View Count: 767
[2017-03-13 19:58:05] |
User147461 - Posts: 33 |
Need a global switch for "Display Name and Value in Region Data Line" sc.GlobalDisplayNameAndValueInRegionDataLine Thank you! |
[2017-03-13 21:46:57] |
This can only be set on Study Subgraphs. There are no plans to add anything else. Also we do not know whether you are referring to globally among all studies or within a single study and apply to all Subgraphs. Anyway we do not plan to add any other settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-13 22:07:37] |
Since the answer is no then I won't explain
