Date/Time: Sun, 12 Jan 2025 18:44:57 +0000
Ray Drawing number accessed by ACSIL study changes when ray moved
View Count: 594
[2017-03-13 17:41:48]
User930315 - Posts: 55
I have written a study using sc.GetUserDrawnChartDrawing that allows me to calculate the current price of a ray drawing for the current bar.
Often when I move the ray referenced by the study the drawing number changes and my study no longer works. I have to find the new drawing number and modify the study parameters to get it to work again.
Is there any way to either access a non-changing drawing identifier, or to create a ray with a static drawing number that won't change when it's modified or moved?
Date Time Of Last Edit: 2017-03-13 17:45:07
[2017-03-13 17:55:52]
The only way to have a non-changing identifier for a Chart Drawing is to have it be added by a custom study and not manually by a user.
You will want to set the LineNumber. Refer to:
http://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#LineNumber
[2017-03-13 21:59:28]
Actually, our answer previously may not be correct.
The LineNumber for the drawing should not change. We are checking on that.
[2017-03-13 22:05:20]
The s_UseTool::LineNumber member variable for a Chart Drawing does remain constant, even if the drawing is moved.
