Date/Time: Mon, 13 Jan 2025 02:58:06 +0000
VpB underlying study of VbP tool
View Count: 935
[2017-03-13 17:29:53]
User132748 - Posts: 159
How can I read POC value of underlying VbP study of VbP tool, which I identified with sc.GetUserDrawnChartDrawing() and DRAWING_VOLUME_PROFILE? I know POC value is in Subgraph[0] of that study but how can I get access to that? Thanks in advance!
BR
[2017-03-13 18:44:21]
Refer to:
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#ProgrammaticallyAccessingVolumeAtPriceData
[2017-03-13 19:02:35]
Thanks for reply.
I'm aware of sc.GetStudyArrayUsingID function but the problem is how to get underlying study ID that is connected with VbP tool that was identified using sc.GetUserDrawnChartDrawing(sc.ChartNumber, DRAWING_VOLUME_PROFILE, DrawingObject, DrawingIndex) with DrawingIndex=-1 (last drawn VbP tool graph on chart)?
[2017-03-14 10:29:04]
In the next release this will be added:
s_UseTool::AssociatedStudyID
If it is nonzero, it will be referring to the associated study identifier.
Date Time Of Last Edit: 2017-03-14 10:29:38
[2017-03-16 16:28:44]
YES!!! Thanks
[2017-03-16 18:28:17]
This is documented here:
https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#AssociatedStudyID
[2017-03-27 07:51:05]
Does s_UseTool::AssociatedStudyID property work in 1531 build? It always returns zero.
My code:
int DrawingIndex = -1; // last drawing
s_UseTool DrawingObject;
if (sc.GetUserDrawnChartDrawing(sc.ChartNumber, DRAWING_VOLUME_PROFILE, DrawingObject, DrawingIndex))
  SCString logMsg;
  logMsg.Format("Underlying VbP study <%i>", DrawingObject.AssociatedStudyID);
  sc.AddMessageToLog(logMsg,0);
[2017-03-27 09:26:41]
We see the problem. We are fixing this now.
We will have a new release out in a couple of hours.
