Date/Time: Sun, 12 Jan 2025 19:05:17 +0000
Volume Chart Issue/Question
View Count: 862
[2017-03-13 12:24:33] |
cmet - Posts: 575 |
My data (CQG) is current showing overnight volume of 137,000 contracts for ES (June contract). In the quoteboard. Using a 3000 volume chart, the overnight session is only showing 24 bars. That would be 72,000 contracts. It should be showing at least 45 bars by now if every bar is 3000 contracts. Possible reason for the discrepancy? |
[2017-03-13 17:47:42] |
Use the Volume study to actually see the volume to confirm the calculations. Also refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-13 17:47:57
