Date/Time: Sun, 12 Jan 2025 18:57:56 +0000
API or CSVs possible with Sierra?
View Count: 750
[2017-03-10 20:52:20]
User515707 - Posts: 6
I am currently on a demo account.
I am using some customized live signal indicator with my demo account .
1st question.
A spreadsheetstudy function from Sierra is inactivated for a demo account. Is there anyway you can activate it for a certain period for my demo account?
2nd question and the most important question.
If I have a live account, Is there anyway I can have a real time APIs? or CSVs?
[2017-03-12 00:05:51]
The Spreadsheet studies are fully active during a Sierra Chart trial.
Furthermore, we show that you have not even logged into Sierra Chart using the account that you have logged into this Support Board with.
This question is vague to us. But refer to these features here which may be helpful:
Advanced Custom Study Interface and Language (ACSIL)
Text/CSV Data Format
Overview of Spreadsheet Studies
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s379 (Write Bar and Study Data To File)
[2017-03-13 17:10:03]
I have a demo account with Transact but I am not sure why you are not able to see it.
Is there anyway I can pull up activity log for my customized indicator?
[2017-03-13 17:31:40]
Follow the instructions here to use your Transact account:
http://www.sierrachart.com/index.php?page=doc/TransAct.php
There is no activity log for a study. If it adds messages to the Message Log, then refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/MessageLog.html
[2017-03-13 18:05:40]
I have checked your suggested information but i was not able to find how to see or download log for my customized indicator.
I can see my customized indicator(signal) on my Sierra chart but i am looking for an activity log for my customized indicator.
For instance, once my live customized signal shows an indication on my sierra chart, i would also like to see that in an activity log or any type of messages for my indicator so i can see that i had a live signal on my sierra chart.
[2017-03-13 18:13:22]
As we previously said there is no activity log for a study. It does not exist.
However, it sounds like you might want to use this ACSIL function to accomplish what you want:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scSetAlert
[2017-03-13 18:46:34]
At this point we are confused. What method in Sierra Chart did you use to develop the "customized live signal indicator"?
[2017-03-14 04:23:36]
It sounds like you are using the Sierra Chart Advanced Custom Study Interface and Language?:
If so, what do you want to accomplish? So you want to access real-time and historical data? Anyway, have a look at:
Data and Trading Communications (DTC) Protocol Server
Your question is very vague and confusing to us.
Date Time Of Last Edit: 2017-03-14 04:24:41
