Date/Time: Sun, 12 Jan 2025 18:42:15 +0000
What the ..........No USDSGD
View Count: 848
[2017-03-10 18:53:34] |
FH87 - Posts: 43 |
No USDSGD.........Sierra....this is a joke mannnnnn that mean incomplete historical data did I set / miss out something ? Date Time Of Last Edit: 2017-03-10 18:56:25
[2017-03-10 19:03:41] |
You will need to use LMAX for this particular currency market: LMAX Trading Service USDSGD is not available from FXCM which we use for the Sierra Chart Forex data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-12 08:13:45] |
FH87 - Posts: 43 |
ok got it.......should change FXCM and replace it.........their data is suckssss look at usdjpy fri data.............how the hell they got a gap for that for fri opening |
[2017-03-12 10:17:02] |
We do not see any missing data on 2017-03-10 for that symbol. Post an image of the chart showing this missing data following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
