Date/Time: Sun, 12 Jan 2025 18:34:56 +0000
Formula Conditions
View Count: 867
[2017-03-10 17:19:22] |
User104854 - Posts: 457 |
I have a formula that I use with 4 conditions that is TRUE if all 4 conditions are met. Can you direct me to where I can find information to have it be TRUE if say, any 2 out of the 4 conditions are met?
[2017-03-10 18:07:49] |
We do not provide formula programming help. This is simply a programming help question. It does sound somewhat complex to program that formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-10 20:09:26] |
Sawtooth - Posts: 4149 |
You'll need to use the OR function with several AND functions: =OR( AND(condition1,condition2), AND(condition1,condition3), AND(condition1,condition4), AND(condition2,condition3), AND(condition2,condition4), AND(condition3,condition4)) |
[2017-03-10 22:21:14] |
I tried that and ran out of text room under the alert condition. I'm using the color bar based on alert condition study. Is there another way to go about this?
[2017-03-10 23:02:13] |
Disregard. I just used the same indicator 4 times with each condition and it works fine. Thanks.
