Date/Time: Sun, 12 Jan 2025 18:39:58 +0000
Combine Range Chart with Numbers Chart
View Count: 607
[2017-03-10 14:55:00]
User172040 - Posts: 70
How do I combine a range chart with a numbers chart? I want to create a range chart of 5 ticks on the ES but I also want to see the bid ask volume within each tick level. I cannot find documentation for this...
[2017-03-10 18:12:49]
You just need to add the Numbers Bars study to the chart:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php
And then set the Bar Period Type in the Chart Settings to Range Per Bar-Standard.
Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar
