Date/Time: Sun, 12 Jan 2025 18:48:07 +0000
HTTP connection
View Count: 540
[2017-03-10 04:29:49] |
User153928 - Posts: 35 |
Hi, all of a sudden I have a problem with HTTP connection show up on my log every 2 minutes saying "shutdown and closed" and "closed no error" whatever that means I already opened the firewall on the computer as per your help information, it is annoying, what else can I do? Thanks Walter |
[2017-03-10 05:10:00] |
You are running an older version of Sierra Chart. Most likely this has been resolved. Update with Help >> Download Current Version.
