Date/Time: Sun, 12 Jan 2025 18:55:14 +0000
open a Forex account with Halifax NZ
View Count: 1307
[2017-03-09 23:16:34]
User78926 - Posts: 69
Hi there,
I want to open a Forex account with Halifax NZ [www.halifaxonline.co.nz] as my broker. Can I do this and connect to my Halifax trading account with my SCs platform? I note they are not listed in your 'Supported Services' however I am unsure if this is a requirement.
If I can, you please direct me to instructions of how to connect?
Rgds, Mark
[2017-03-10 01:20:41]
Yes you can use that brokerage because they support Interactive Brokers Trader Workstation TWS:
https://www.halifaxonline.co.nz/platforms/trader-workstation/
[2017-03-10 06:54:25]
..ok thx so does mean I can use my SCs platform? [have never and don't intend to use TWS]. As I said I want to use SCs in conjunction with Halifax NZ.
If that is the can you please direct me to connection setup?
Thx and regards, Mark
[2017-03-10 06:59:00]
The only way to use Sierra Chart with that broker is to use the Trader Workstation that they offer.
Otherwise you cannot.
[2017-03-10 07:43:43]
ok so what you are saying is that the only FX broker options is what you list on your Website?
https://www.sierrachart.com/index.php?page=doc/Data.php
Rgds, Mark
[2017-03-10 07:55:54]
Yes.
