Date/Time: Sun, 12 Jan 2025 18:57:26 +0000
Automatic rollover of all charts to June contract
View Count: 702
[2017-03-09 14:02:37] |
User57584 - Posts: 30 |
After a non understood issue with my Sierra software, I went to a saved copy from last week (I could not move my charts anymore except from the right scale, and it was very slow). It worked well again, but now all my charts have switched to the June contract and I do not understand why. All my charts are checked for "Automatic Rollover Futures Symbol" on the Main Settings, but the rollover normally happens at the end of the month. I have been obliged to uncheck the above mentioned to get the March prices. Do you have an idea where this could come from ? Thank you in advance. Jean-Marie Boulay |
[2017-03-09 14:09:06] |
Oops, my mistake! I see that it is normal as rollover is today. Sorry. |
[2017-03-09 16:59:02] |
In regards to: (I could not move my charts anymore except from the right scale, and it was very slow).
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
