Date/Time: Sun, 12 Jan 2025 18:54:09 +0000
bad data
View Count: 612
[2017-03-08 21:42:30] |
User28682 - Posts: 233 |
Wondering how you edit out these bad data points. When I right click on the chart and go to > Edit/Download Data Intraday Chart, I dont see the bad data point to edit out. When I right click on the chart and pick Chart Values/Crosshair I do see the bad point. Thanks TT |
bad_data_point.png / V - Attached On 2017-03-08 21:41:34 UTC - Size: 27.97 KB - 201 views |
[2017-03-08 22:22:21] |
This is during after-hours trading and is not necessarily bad data but we have removed it anyway. Follow the instructions here to re-download the data: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
