Date/Time: Sun, 12 Jan 2025 18:55:39 +0000
TPO Indicator
View Count: 2161
[2017-03-08 16:10:39]
User208632 - Posts: 2
Can I get a Chartbook of the TPO indicator with the following:
Letters instead of blocks
Plot the Initial Balance
Plot the Open
Extend POV & VAH & VAL
Have the start be 7:30 (Mountain Time for me) and the end go throughout the globex session (i.e. 1 market profile per day starting at the New York open time)
Attached is what I have. I think I'm close, but it looks off when I compare it to my Volume By Price chart, which has all of the above settings.
Thank you very much for the help.
Craig Schultz
imageTPO.PNG / V - Attached On 2017-03-08 16:10:00 UTC - Size: 56.67 KB - 746 views
[2017-03-08 19:15:39]
Did you want the Point of Control, Value Area High/Low to be based upon the TPOs or Volume?
[2017-03-08 19:18:34]
TPO's
[2017-03-09 17:39:37]
The Chartbook is attached.
Here are instructions to use it:
http://www.sierrachart.com/index.php?page=doc/Chartbooks.html#UsingChartbookProvidedBySierraChartSupport
Let us know if that helps.
attachmentTPO Chartbook.cht - Attached On 2017-03-09 17:39:25 UTC - Size: 30.75 KB - 319 views
