Date/Time: Sun, 12 Jan 2025 19:00:16 +0000
test display from chart from chart
View Count: 658
[2017-03-08 15:30:59] |
sierra28 - Posts: 120 |
hello support, is it possible to display this number above footprint ? thanks |
Capture.PNG / V - Attached On 2017-03-08 15:25:16 UTC - Size: 20.61 KB - 234 views Attachment Deleted. |
[2017-03-08 18:07:38] |
What does that number represent?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-08 18:07:53
[2017-03-11 11:21:19] |
it is the delta from a chart using text display for studies from chart i have try to move up in the studies list but this number is always under vp. |
[2017-03-12 10:22:01] |
Refer to this section in regards to the display order of Text drawings: https://www.sierrachart.com/index.php?page=doc/Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-12 10:22:15
