Date/Time: Sun, 12 Jan 2025 18:40:14 +0000
Choice to end IB at RTH
View Count: 629
[2017-03-08 10:41:30] |
Rino - Posts: 124 |
Hi, It would be a nice option to end IB at the RTH session. As you can see it goes in to the O/N session as well. Thanks as always |
Attachment Deleted. |
[2017-03-08 18:52:03] |
You can do this with the High/Low for Time Period-Extended study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s313 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-08 18:52:21
