Date/Time: Sun, 12 Jan 2025 18:39:09 +0000
seconds charts' set
View Count: 610
[2017-03-08 10:26:02] |
User145792 - Posts: 22 |
How do i set the charts to a seconds period? Cheers |
[2017-03-08 17:51:36] |
There are several ways this can be done. Refer to this page: http://www.sierrachart.com/index.php?page=doc/ChangingPeriodOfBars.php This is the specific setting in Chart Settings which you can use to set seconds: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysMinutesSeconds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
