Date/Time: Sun, 12 Jan 2025 15:15:31 +0000
unable to load current version
View Count: 569
[2017-03-08 02:41:14]
User175327 - Posts: 36
Hi- I am currently running version 1522....when i go to "help" "download current version" i get the following:
not sure what the issue is....please help.
The update is being downloaded in the background. When it is complete, you will be prompted. | 2017-03-07 20:38:25 *
HTTP connection to www.sierrachart.com:80 (10) | Creating socket. | 2017-03-07 20:38:25
There is no new version available. | 2017-03-07 20:38:27 *
HTTP connection to www.sierrachart.com:80 (10) | Socket gracefully closed by remote side. | 2017-03-07 20:38:30
HTTP connection to www.sierrachart.com:80 (10) | Received socket Close event | 2017-03-07 20:38:30
HTTP connection to www.sierrachart.com:80 (10) | Initiating close of socket by core. | 2017-03-07 20:38:30
HTTP connection to www.sierrachart.com:80 (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-03-07 20:38:30
HTTP connection to www.sierrachart.com:80 (10) | Closed. | 2017-03-07 20:38:30
[2017-03-08 03:01:13]
Yes this does make sense because the current version is 1522. If you want the prerelease use Help >> Download Prerelease.
[2017-03-08 03:03:35]
Thx!! I guess I should try actually reading next time. Sorry for the lost time.
Cheers!!
