Date/Time: Sun, 12 Jan 2025 15:11:40 +0000
User Question - linear regression study
View Count: 925
[2017-03-07 17:49:17] |
Sierra Chart - Max - Posts: 5778 |
Can you increase not only the standard deviation but the # of bars representing the those SDs?
In settings and inputs, it only looks like you can increase the # of them but not create a line representing them, lets say I wanted to look at 2, 4 and 6 SD simultaneously. Can you manipulate the study settings to do so? Sierra Chart Support |
[2017-03-08 05:12:49] |
Yes. This is done with the Number of Bars Input. Refer to the documentation:https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s119 We are not certain exactly what you want to do but it sounds like you might want to add the study 3 times to the chart. You can do that. Refer to: Chart Studies: Adding/Modifying Chart Studies Also questions like this must go on the Support Board: https://www.sierrachart.com/SupportBoard.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-08 05:13:36
