Date/Time: Sun, 12 Jan 2025 15:14:56 +0000
DOM - display bid/ask spread
View Count: 1124
[2017-03-07 12:40:58] |
AndyL - Posts: 119 |
When there are bids/offers in the DOM further out that are not displayed on the screen, the bid/ask spread as well as depth totals are out of view. Is there a way to still display them somehow? I know i could limit the maximum depth levels - but i dont want to do that for all instruments and this is a global setting..
[2017-03-07 18:43:27] |
Not with how this is currently designed. You just have to limit the Maximum Depth Levels Displayed through Global Settings >> Chart DOM Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
