Date/Time: Sun, 12 Jan 2025 15:13:04 +0000
Single Profile from "X" Date/Time
View Count: 645
[2017-03-07 11:52:21] |
infpz - Posts: 826 |
Regarding this section: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#TPOProfileSettings From Start Date-Time + Time Length: This will create a single TPO Profile from the starting Date-Time specified by the Single Profile Start Date-Time Input. The profile links is specified by the Profile Time Period Length and Profile Time Period Type Inputs. Please see the attached images 1 and 2 for my settings. When I push apply, I get the results shown in image 3. (date reverts to 0 and the time is a little strange looking, definitely not what I entered) The chart itself (image 4) looks good, but I can't be sure it's accurate because the date/time at the bottom doesn't display as I had indicated. Can you point me in the right direction as to where I am going wrong? |
[2017-03-07 12:11:02] |
For the date use 2017-02-16 We also see a documentation error. And that has been corrected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-07 12:12:19
