Date/Time: Sun, 12 Jan 2025 15:06:58 +0000
Chart green / red box
View Count: 1023
[2017-03-07 08:50:08] |
User687828 - Posts: 17 |
Hello, what is the information displayed in this box? 3? L? I can see it changes from green to red when the chart is scrolled and latest prices are not being shown but what other info is this providing? Also can I move it from the right bottom to another location, for example right top corner? Thanks.
SierraChart_2017-03-07_15-46-21.png / V - Attached On 2017-03-07 08:49:26 UTC - Size: 2.51 KB - 210 views |
[2017-03-07 17:37:15] |
It cannot be moved. It is documented here: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#LRChartSettingsIndicators Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
