Date/Time: Sun, 12 Jan 2025 15:13:59 +0000
Daily High/ Low in DOM
View Count: 1464
[2017-03-07 07:03:58] |
nicktrader - Posts: 727 |
I am still looking for the setting of the Daily HIGH/ Low in the DOM. I know there is a way but couldn't find it. |
[2017-03-07 17:36:02] |
This is controlled through the Graphics Settings window. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php The specific items you need to change are: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php#ChartDOMDailyHighLine Or: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php#TradeDOMDailyHighLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-08 08:47:17] |
User19165 - Posts: 346 |
So....I have both of those enabled but there are no daily high/low lines showing up in my DOM - why might that be?
[2017-03-08 08:59:38] |
I do have the same problem - both enable but no lines
[2017-03-08 09:08:56] |
Are you referring to the Chart DOM or Trade DOM? And go to either one of those, depending upon which one you are using, and then select Window >> Current Quote Window to make sure there are nonzero Daily High and Daily Low values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-08 09:16:13] |
I am refering the Trade DOM. Daily HIGH at the moment 11980. Do not know what to do concerning your second sentence |
Trade DOM.png / V - Attached On 2017-03-08 09:13:52 UTC - Size: 8.29 KB - 231 views |
[2017-03-08 09:27:31] |
We think we understand the reason for the problem. Increase the width of those Daily High/Low lines to at least two pixels. We have to see why the gridlines is being drawn after. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-08 09:49:11] |
I am using two different broker/ instances. The right DOM do have the HIGH Line and it has the same small pixel size. I changed the pixel size in the left one but I can't see any line. I do not know why the right one have lines but not the left one In both I am using 1522 |
2 Trade DOMs.png / V - Attached On 2017-03-08 09:47:44 UTC - Size: 59.21 KB - 283 views |
[2017-03-08 09:58:40] |
Understand that there are two separate Graphics Settings windows. Make sure you are using the correct one. This is explained here: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
