Date/Time: Sun, 12 Jan 2025 14:51:47 +0000
market depth request
View Count: 663
[2017-03-07 03:09:59]
User20450 - Posts: 330
is there a way on your next update or when you have time if you can have option to just plot right side numbers and not ones over bars ? thanks
Private File
[2017-03-07 04:09:55]
Do you mean just the current market depth values?
[2017-03-07 13:00:49]
correct just ones on right
[2017-03-07 17:51:22]
Therefore, set the Show Quantity Numbers Input to No on the Market Depth Historical Graph study.
And use Trade >> Show Depth:
http://www.sierrachart.com/index.php?page=doc/TradeMenu.html#ShowDOMDepth
In newer versions of Sierra Chart, the Chart/Trade DOM columns can be customized for each individual chart. So you can just have a single column with market depth.
Date Time Of Last Edit: 2017-03-07 17:52:10
[2017-03-07 18:30:55]
im talking about in picture i posted , left over depth totals kept on
