Date/Time: Sat, 26 Sep 2026 02:01:38 +0000
How to release sc.MakeHTTPRequest memory
View Count: 1057
[2017-03-07 01:13:11]
User612903 - Posts: 51
I'm struggling with something : everytime i use : "sc.MakeHTTPRequest" in a custom study Sierrachart seems to use some memory. This memory seems to be never released.
Is there a way to release that memory ? Or Prevent it ?
You can do a simple study with this line :
sc.MakeHTTPRequest("URL");
And you will see in windows the RAM increasing at each call.
Am i missing something ?
Thanks for your help,
Regards
Date Time Of Last Edit: 2017-03-07 01:14:14
[2017-03-07 04:03:19]
The only persistent memory use will be the maximum size of the data received among the HTTP requests.
There will be some temporary memory use for the network socket, but that eventually will get released when the socket is closed which should happen within a minute.
If you are noticing more than the above, then this would seem to be a system specific issue or something else you are doing which is using a lot of memory.
Date Time Of Last Edit: 2017-03-07 04:03:48
[2017-03-07 11:42:47]
Thank you very much for your reponse.
Maybe what i see is the 3 lines in the log window :
"Making http request"
"connected"
Is there a way to disable this or prevent all log in the message window so it does not affect the ram ?
Regards
[2017-03-07 11:44:58]
No, there is no way to prevent those messages but those are not going to consume much memory. Next to nothing
[2017-03-07 12:48:14]
Ok thank you very much for your help
