Date/Time: Sun, 12 Jan 2025 13:58:00 +0000
Dublicate chart
View Count: 714
[2017-03-06 11:06:25]
AKR - Posts: 523
I tried now several times and everytime what happens:
I dublicate a chart from a CB to an other. I dont change anything in that chart in the new CB.
When I go back to the first CB (I copied from) and I close the chart there it is also closed in the new CB.
But only thing I want is to transfer it from CB1 to CB2....
What am I doing wrong?
Thx!
[2017-03-06 11:09:30]
This does not make any technical sense.
Describe the precise steps you are following and how you are coming to this conclusion.
Either you are not doing this correctly or there is a misunderstanding. Perhaps you are using Window >>Window Always Visible?
[2017-03-06 12:12:36]
AKR - Posts: 523
no I dont use that.
I have a chart in CB1. I attach it. I go to chart dublicate chart to CB2. I go to CB 2 and its there. I go to CB1. I right click on chart and choose "close active window". and then its also gone in CB2. But I ll give it an other try now.
[2017-03-06 12:18:30]
AKR - Posts: 523
yes, happened again. But now i will just make a new chart.
[2017-03-06 17:58:36]
We need you to exactly describe the particular menu commands you are using if you are still having a problem.
