Date/Time: Sun, 12 Jan 2025 13:46:38 +0000
ger30 data question
View Count: 630
[2017-03-06 10:07:07] |
EuropeanTrader - Posts: 290 |
Hi, please see attached pic. I chose 21 sec chart time frame but time below says that each bar is not 21sec? thanks http://www.sierrachart.com/image.php?Image=1488794793345.png http://www.sierrachart.com/image.php?Image=1488794816554.png |
[2017-03-06 17:22:44] |
From our perspective this is hard to tell. Enable this option for the chart: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#IncludeColumnsWithNoData (Include Columns with No Data) This way you can tell if there any missing bars. For that symbol and using that option, we do not notice any missing bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-06 17:23:14
