Date/Time: Sun, 12 Jan 2025 13:35:31 +0000
Questions about new CTS T4 connection model
View Count: 697
[2017-03-06 08:22:44] |
User514837 - Posts: 47 |
I will be trading through Dorman and be using the Sierra platform. I am interested in this new connection model: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel My first question is: 1) If I use this model, the cost is the Sierra chart exchange data feed for 25$, plus the 10$ CTS order routing connection, plus 0.10$ per trade. What is the difference between user the older CTS connection model (in cost)? 2) That link also says that this 25$ cost is only for 10 real-time symbols. Can you please explain what this means? Only 10 symbols are available to trade? Or you can have 10 different live charts on your screen? I'm not sure. |
[2017-03-06 08:51:19] |
1. Under the older model it is USD.50 per contract per side and 25USD/month minimum. And there is no requirement to use the Sierra Chart Exchange Data Feed. 2. This means streaming real-time data can only be provided for 10 symbols at a time. For 100 symbols the cost is 35 USD per month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-06 08:52:30
