Date/Time: Sun, 12 Jan 2025 14:00:14 +0000
Chart Dom grid lines
View Count: 1663
[2017-03-06 04:40:16]
Maxuel - Posts: 5
Hi! Is there some way to place horizontal grid on the chart dom?
Also, is there some way to adjust the chart dom value background?
Thank you!
[2017-03-06 07:29:34]
The horizontal grid lines do not extend onto the Chart DOM.
But you can use the Chart Values tool and set it to always be enabled and that will show the vertical axis label on the Chart DOM.
Refer to:
Chart Drawing Tools: Chart Values/Crosshair
What specific value are you referring to on the chart DOM? However, refer to:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM
Date Time Of Last Edit: 2017-03-06 07:30:49
