Date/Time: Sun, 12 Jan 2025 14:05:16 +0000
install Sierra on 2nd computer -- connection issues
View Count: 634
[2017-03-06 04:31:46]
User11638 - Posts: 21
I have installed Sierra on a second computer and when I have Sierra running on both systems I get a message in the message log indicating that I have the same credentials on two computers. The message further says to contact Customer Support, so here I am!
Thank you.
[2017-03-06 04:55:33]
We see you are using CQG and the message you are seeing is from CQG and it is indicating that the CQG system is preventing you from having 2 simultaneous connections.
You will need to contact your broker about that. It is out of our control.
